November 2, 2021 at 9:46 am
baby_engineer
SubscriberHow can i access the directed energy deposition module?
November 2, 2021 at 1:50 pmSurya Prakash
If you are planning to perform a directed energy deposition analysis in Ansys Mechanical Workbench, you can do that by coupling a transient thermal and static structural analysis. This will only give us macro-level distortion and stress results which will be helpful to change the orientation or to prevent build failures. If you are looking for micro-analysis, you might have to consider using Mechanical APDL with your own subroutines. Here are some useful links -
4.9. Define AM Process Steps (ansys.com)
6.4. Performing a Directed Energy Deposition (DED) Process Simulation (ansys.com)
Additive manufacturing process (DED) simulation help ÔÇö Ansys Learning Forum
Regards Surya
November 3, 2021 at 10:14 ambaby_engineer
SubscriberThanks for your answer and for the helpful links!
November 15, 2021 at 7:18 pmAmaranth
SubscriberHello, I am new to ansys and I am trying to simulate the DED of Ti64 on steel baseplate using ansys workbench. However, I am not sure on how to go about it .. I am using Ansys student 2021.. Hence I do not have a customer Id and cannot login to see the Answers posted by . Please let me know how to proceeed with this !
November 16, 2021 at 7:59 amSurya Prakash
You can search the same, i.e., "Direct energy deposition process" in Ansys Help, which would be installed in your computer while installing the Ansys student 2021. You can search Ansys help in your start menu to find it. Those are the same links that I shared here.
Regards Surya
July 13, 2023 at 2:26 pmPrajwal Manjunath
SubscriberHi, I am new to ansys ded simulation. In my dissertation I am working on reducing the residual stress by changing pattern direction and nozzel angle. I need help soving this problem. Can you send material regarding this
Viewing 5 reply threads- The topic ‘Directed energy deposition’ is closed to new replies.
4232
1494
1375
1197
