3D Design
3D Design
Dimensioning a tube
    • Roberto
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello Is it possible to quote the length of the tube? SpaceClaim is unable to engage the round parts, the only way I could find the measurement was to project the curve Best Regards
    • Devendra Badgujar
      Hi Roberto
      Let me look into this, I will get back to you.
      Regards.
    • Devendra Badgujar
      Hi Roberto Yes it is possible to quote the length of the tube. You can dimension the tube from the Dimensions option in the Detail Tab. You have to select the reference from where you need to start dimensioning. I have attached a video demonstrating it for your reference. Regards.
    • Roberto
      Hi Devendra Badgujar Thanks for the video, while there is a method to quote the shorter side?
      Best Regards
    • Devendra Badgujar
      Hi Roberto
      You can use the same method shown in the video to quote the dimensions of the shorter side.
      Regards.
    • Roberto
      Hello Devendra Badgujar I can't, it always takes the longer side Regards
    • Devendra Badgujar
      Hi Roberto I have attached a video to demonstrate the method to quote/Dimension the shorter side. Please check it. Regards.
    • Roberto
      Ok then and how I did it, thank you very much
      Best Regards
    • Devendra Badgujar
      HI Roberto Yes the way you did it that can be alternate method too, You have to similarly create the plane on the axis and on the plane sketch construction lines on the sides  and you can then dimension those lines. Regards.
Viewing 8 reply threads
  • The topic ‘Dimensioning a tube’ is closed to new replies.
