TAGGED: do-irradiation, do-radiation-model, glass, solar, solar-radiation
August 13, 2024 at 5:11 pm
a.eissa
SubscriberHello,Â
I am simulating solar radiation incident on water passing between two layers of quartz glass. I am using DO radiation model and I want to know what is the diffuse fraction value that I should use for every surface (Upper glass surface - Glass-Water interface, etc.). Changing the value from 0 to 1 is changing the results abruptly. What is your advice on this value.Â
Thanks a lot.
August 14, 2024 at 9:56 am
Forum ModeratorGiven it's a fraction changing from zero to one will likely have a huge difference in the results. Click on Help in the panel to get more information.Â
