July 5, 2021 at 9:24 am
Diabq
SubscriberI am using ANSYS 2020R2 and Ansys 18.2 to solve the same problem the mesh used is the same and all the solution's parameters are too yet I still face a difference of 7% in my results .
Most importantly, the solution using fluent 18.2 takes up to 9 hours the solution using 2020R2 takes under an hour to solve
Any idea what is the reason behind this difference
July 5, 2021 at 10:10 amRob
Forum ModeratorWhat models are you using, and how does the convergence compare?
July 5, 2021 at 10:18 amDiabq
Subscriberviscous laminer and they both converage at 1e-6
July 5, 2021 at 2:13 pmDiabq
Subscriberresiduals as well as the monitors are the same in both cases
July 5, 2021 at 3:42 pmRob
Forum ModeratorAnd what monitor/result is different? Please post images to show the changes otherwise there's not a lot we can do.
Viewing 4 reply threads- The topic ‘Different versions different results’ is closed to new replies.
5649
1885
1403
1303
