March 23, 2023 at 5:31 pm
PRAJVAL PRASAD INAMDAR
SubscriberI am performing thermomechanical fatigue analysis of exhaust manifold. For that I want to run the fluid simulation for bigger time step so that a steady state temperature is achieved for that time step. Then I want to give that temp profile to thermal model having less time step to get the thermal stresses induced. Can I do this in ansys ? Ani if yes how should I proceed? Also can I add temperature dependent properties of material as at high temperatures of exhaust the properties change drastically? Please help. I shall be obliged.
Thanks in advance.
March 27, 2023 at 12:55 pm
Rahul
Ansys EmployeeHi,
Is it a 1-way or 2-way analysis?
Time Step Size and Number of Time Steps for fluent are controlled by system coupling, so the values specified in fluent are ignored.Â
If it is 2-way, refer 42.5. System Coupling Related Settings in Fluent (ansys.com) and System Coupling Related Settings in Mechanical (ansys.com) for settings required as inputs in both participants.
March 28, 2023 at 5:39 am
SubscriberIt's a 2 way fsi. I was to make the fluent come to steady state and then transfer that data to thermal. I want have time step of fluent to be less than thermal (say 0.001 fluent and 0.01 for thermal) and I want to couple them. Basically I want that after some iterations of fluent then only thermal should start calculation.
Thanks.
March 30, 2023 at 8:18 am
Rahul
Ansys EmployeeHiÂ
You might want to refer to Steady-Transient analysis Transient Analysis Type (ansys.com)In such steady-transient analyses, System Coupling will show the overall analysis type as Transient, while the physics with the shorter/faster timescale is solved as steady-state.
- The topic ‘Different time step for Fluent and Transient Thermal coupling’ is closed to new replies.
4723
1565
1386
1242
