August 19, 2022 at 2:00 am
Sagar Patil
We are facing the error message after hitting the run button. Please refer the attached image for more details.
Two Scenario:
1) Two different part assigned with different material- Structural Steel S275N & Cast Iron (Error message)
2)Â Two different part assigned with same material - (Working fine)
August 19, 2022 at 3:26 am
Charudatta Bandgar
SubscriberHello SagarLive
We can connect at 2PM IST to discuss the issue as you had mentioned in the mail, and continue the discussion through mail.Â
Regards.
August 19, 2022 at 4:03 am
Sagar Patil
SubscriberCharudatta BandgarÂ
Thanks a lot for your reply.
Can you please make sure Release 2021 R1.6
- The topic ‘Different material assigned dsl gave error message’ is closed to new replies.
