Electronics
Electronics
Differences between HFSS polyline and spline
    • Eric Chen
      Hi,everyone.I've wrote a .py script to create 200 points and connected them by using spline.
      However,it seemed that polyline didn't follow the shape of spline,is there any wat to fix that?
      The black line was the spline I created by 200 points,and the pink one was the polyline.
      Thanks for your help!
    • Praneeth
      Hi Eric Chen,
      Thank you for reaching out to the Ansys learning forum.
      Please note that the polyline option can be used to define a single object by combining straight, spline and arc line segments. You can use "set edge type" from the shortcut menu while drawing. In your case, it looks like straight edge is selected.
      More details can be found in the HFSS help document under section "Drawing a Polyline".
      Best regards,
      Praneeth.
