July 12, 2021 at 6:21 am
MDave
SubscriberI performed transient analysis using Eulerian-Granular model in Fluent. I observed the difference in the magnitude of velocity in vectors and contour plots. Please explain the reason behind this.
Thank you.
Regards
M. Dave
July 12, 2021 at 6:27 amJuly 12, 2021 at 10:53 amRob
Forum ModeratorWhat happens if you plot the contour with node values off?
July 12, 2021 at 11:05 amDrAmine
Ansys EmployeeGlobal/Local Range----Node Values On / Off.
July 12, 2021 at 1:20 pmMDave
SubscriberI've understood now. Thank you very much.
July 12, 2021 at 4:00 pmDrAmine
Ansys EmployeeÂÆ’Ã¦Ã¬ÂÆ’æî
Viewing 5 reply threads- The topic ‘Difference in the magnitude of velocity vector and velocity contour in Fluent’ is closed to new replies.
5759
