Difference in motions
    • r.abbasi
      I am analyzing two different shapes in HR, like below:
      1) I compare their heave displacement with the deactivation of some freedoms, at the same wave identification
      2)connect them to the same beam and fix the hinge (without deactivating freedoms), at the same wave identification like 1
      part 1, showed that shape 2 displaced more, but part 2 showed that shape 1 displaced more!
      I'm not sure, is there any problem with my analysis? because there should not be a difference between comparison floats when the float is connected to a beam or without a beam
    • ErKo
      Hi
      Can you give some details what type of system/software you use and what type of analysis you run- so much more info is needed.
      All the best
      Erik
    • r.abbasi
      Im using Ansys AQWA as I taged.
      time response analysis
  • The topic ‘Difference in motions’ is closed to new replies.
