January 26, 2024 at 6:50 am
Ali Qasim
SubscriberHi everyone,
I am modeling a cross-flow energy exchanger for heat transfer from humid air to a cold fluid separated by the membrane. I have performed the simulation and for validation purposes compared the results with experimental results and analytical calculations. I used the effectiveness-NTU method for the analytical calculations of sensible effectiveness.
Surprisingly, there is a huge difference between analytical and numerical simulation values.
I have used symmetry boundary conditions in numerical analysis (half domain is modeled with half flow rate).In the case of analytical calculations, do I need to use “half domain with half flow rate” or “full domain with full flow rate”??? In both cases, the results are different.
January 31, 2024 at 6:48 am
Kishan Konannavar
Ansys EmployeeHello
How does the numerical solution compare with experimental results?
It is possible to model a smaller domain if the actual geometry and physics allow. If the reduction in domain is appropriately accounted for in the form of geometry and boundary conditions in Fluent, you should get accurate results.
Given that different analytical results are obtained for "full" and "half" domains, I would suggest going with full domain, which would be simpler. "Halving" a domain needs to be appropriately accounted for in the analytical treatment as well in the effectiveness relations that may have been used.
If not checked out already, I would suggest visiting the following materials on AIS which could be of some help
How Heat Exchangers Work | Ansys Innovation Courses
Thank you
Regards
Kishan
- The topic ‘Difference in Analytical and Simulation results’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4592
1494
1386
1209
