February 17, 2021 at 3:04 pm
oumaimalahmar.ol
Subscriberhello someone can explain to me the difference between membrane stress and top/bottom stress in workbench and that it is normal that the membrane stress is higher than the top/bottom stress.n -
February 18, 2021 at 2:35 pm
oumaimalahmar.ol
Subscribercan you please answer me.n -
February 19, 2021 at 4:07 am
peteroznewman
SubscribernMembrane stress is at the middle of a shell element.nIf you have a rectangular plate with one end fixed and put an axial tension along the length of the plate (x direction), that will create membrane stress. The top, middle and bottom of the shell element all have the same normal stress in the x direction.nIf you put a force in the -y direction on the end of the plate, causing the plate to bend down, that will create positive (tensile) normal x stress at the top and negative (compressive) normal x stress at the bottom, but at the middle the normal x stress will be zero.n -
February 22, 2021 at 1:58 pm
oumaimalahmar.ol
SubscriberThank you n
- The topic ‘difference between membrane stress and top/bottom stress’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1220
1118
1015
