TAGGED: antenna, antenna-efficiency, beam-width, directivity, gain
July 31, 2020 at 6:13 pm
Navya Chode
Forum ModeratorWhy do the datasheets of antennas will have Gain specification rather than directivity?
July 31, 2020 at 6:14 pm
rtk
Ansys EmployeeHello Navya,
By definition, directivity is the ability of an antenna to focus the radiation to a particular direction, whereas, the gain is the ability of the antenna to convert the input power into radio waves in a particular direction. Gain is the combination of the directivity and the electrical efficiency of the antenna where, electrical efficiency of an antenna takes into account the matching between the feed line and antenna as well as the internal losses in the antenna. Hence gain is always less than the directivity because most of the antennas have some internal losses. Also, note that gain is practical and measurable term.Â
Hope that addressed your concern!
Navya Chode
Forum ModeratorThen how do the manufacturers convey the direction properties of the antenna?
Charlotte Blair
Ansys EmployeeHi Navya,
This is accomplished by the Half Power Beam Width (HPBM) specification which indicates the broadness or the narrowness of the antenna radiation pattern. Further, this HPBM is divided into horizontal and vertical beamwidth to cover azimuthal and elevation planes, respectively.Â
June 29, 2023 at 12:40 pm
Ming Yang
SubscriberFurther the question, is there a way to express HPBW so that I can plot post-processing HPBW vs sweep angle?
I can't find it using 2023R1
September 28, 2023 at 11:05 am
Strato Emulator
SubscriberWith the Strato emulator, you can enjoy a wide range of Nintendo Switch ROMs. Following an extensive period of development and refinement, this emulator has finally reached a stable state and is now available for download.
- The topic ‘Difference between directivity and gain’ is closed to new replies.
5719
