July 31, 2020 at 5:47 pm
NKC
Forum ModeratorI was going through the various antenna characteristics and found the usage of many varieties of dB unit!.I would like to know the difference between dB, dBm, and dBi. If anyone can pour some insight that would be helpful.Thanks
VivekKamble
Ansys EmployeeHi
The decibel (dB) is one-tenth of the Bel unit and it is a logarithmic unit of measurement of the ratio of two powers, voltages, currents, pressures, etc. Unlike the absolute measurements such as milliWatts, decibels are a relative measurement unit. The "m" in dBm refers simply to the fact that the reference is 1 milliWatt (1 mW) i.e., decibels relative to one milliWatt. Thus, a dBm is a measurement of absolute power. The unit of measurement dBi mainly refers to the gain of an antenna. The 'i' stands for 'isotropic', which points out that the change in power is referenced against an isotropic radiator. An isotropic radiator is an ideal transmitter that radiates useful electromagnetic field in all directions with equal intensity and at 100% efficiency, to a three-dimensional space. This type of antenna does not exist in reality as it is a hypothetical antenna. Still, it’s used as a reference for comparing antenna gains.
NKC
Forum ModeratorWell!That answered my query. Thank You!?
- The topic ‘Difference between dB, dBm and dBi’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4167
1487
1318
1171
