ANSYS製品
ANSYS製品
Difference between AUTO_SURF_TO_SURF_TIEBREAK (Option 1) and TIED_SURF_TO_SURF
    • yuka.kusama.9t
      【Difference between CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK (Option 1) and TIED_SURFACE_TO_SURFACE
      The analysis results differ between a model joined with CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK (Option 1) and a model joined with TIED_SURFACE_TO_SURFACE.
      What is the difference between CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK (Option 1) and TIED_SURFACE_TO_SURFACE?
      CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK (Option 1) is described as follows:
      Eq. 1: Tracked nodes that are in contact, or that subsequently come into contact, will permanently stick; tangential motion is inhibited.
      For reference, the results from TIED_SURFACE_TO_SURFACE match those from a model with node sharing.
      【CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(OPTION1)とTIED_SURFACE_TO_SURFACEの違い】
      CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(OPTION1)で結合したモデルとTIED_SURFACE_TO_SURFACEで結合したモデルで解析結果が異なります.
      CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(OPTION1)とTIED_SURFACE_TO_SURFACEでは何が異なるのでしょうか.
      CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAKのOPTION1は以下のような内容です.
       EQ.1: 接触したスレーブ節点はそれ以降固着します.接線方向の動きも許されません.
      ちなみに,TIED_SURFACE_TO_SURFACEで結合したモデルの解析結果と,節点共有で結合したモデルの解析結果は同じでした.
      よろしくお願いします.
    • Satvik
      Hello User,
      • TIED_SURFACE_TO_SURFACE enforces a permanent, unbreakable tie with no sliding or separation, suitable for rigid or welded connections.
      • CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK allows for initial tying but enables failure and subsequent sliding/separation, making it ideal for modeling debonding or adhesive failure.
      • Tiebreak contacts use penalty-based formulations and require careful definition of failure criteria, while tied contacts are constraint-based and do not allow for failure.
  • このトピックに返信するには、ログインする必要があります。
