November 9, 2024 at 10:19 am
zahra mansouri
SubscriberHi.
I have designed a magneto optic Wave guide and simulated it in the lumerical mode solution version 2017. The results showed the difference between Neff in forward and backward direction. Now I simulate my waveguide that I designed in version 2017 in the version 2024. The answers in this version doesn't show any difference between Neff in forward and backward direction. Why I get this two different answers?
November 11, 2024 at 7:44 pm
Guilin Sun
Ansys EmployeeWhich product you are using? FDE? Could you elaborate more how do you select the forward and backward direction in FDE?
If it is from 3D FDTD, you can change the source injection direction. But I tested this online case and the result is the same, since it uses bandstructure method regardless the source injection direction: https://optics.ansys.com/hc/en-us/articles/360042038613-Bandstructure-of-a-magneto-optical-waveguide
November 11, 2024 at 9:23 pm
zahra mansouri
SubscriberÂ
Thank you, dear Guilin Sun, for your guidance. Â
I use the FDE solution in Lumerical Mode Solution to simulate a cylindrical magneto-optic waveguide in order to obtain the mode profile. For the forward direction, I apply the magnetic bias in the y direction, which is perpendicular to the propagation direction, and for the backward direction, I use the magnetic bias in the -y direction. I define the magneto-optic material in both forward and backward directions using matrix transformation, as outlined in the Lumerical guidelines on the Ansys website. Â
Now, when I simulate this structure in Lumerical Mode Solution 2017, the propagation characteristics, such as Neff, show a significant difference between the forward and backward directions, which is important for our goals. However, when I simulate this structure in both directions using Lumerical Mode Solution 2024, the difference between Neff in the forward and backward directions is very close to each other, resulting in a negligible difference that could change our design goals
November 11, 2024 at 9:31 pm
Guilin Sun
Ansys EmployeeIf you mean you use exactly the same file but different mode versions, it might be a bug. Please contact your account manager or CP to send us your file so we can investigate in more details.
November 12, 2024 at 8:24 pm
zahra mansouri
Subscriberyes i use the same file in different mode versions. my structure is a cylinderical magneto-optic waveguide. but when i try a plane magneto optic waveguide then the propagation characteristic is the same in two mode version. is it a bug in cylinderical analysis? how can i send you my simulation file?sorry i couldnt find in my ansys account that how to send my file.
November 12, 2024 at 10:19 pm
Guilin Sun
Ansys EmployeeI am not sure if you are testing the same file in 2017 version and 2024 version, as you said you are trying "a plane magneto optic waveguide". Your previous file was for cylinderical magneto-optic waveguide. If something changes you may not be able to justify one is wrong. If you cannot send file, please ask your account manager to help you.Â
November 23, 2024 at 9:28 am
zahra mansouri
SubscriberDear Guilin SunÂ
I used a plane magneto optic Wave guide for testing propose. I simulate a plane magneto optic waveguide in version 2017 and 2024 and I get the same answer. But when I simulate my project ( a cylindrical magneto optic waveguide) in version 2024 and 2017, I get difference answer.
Can I send my simulation files here?
November 27, 2024 at 9:50 pm
Amrita Pati
Ansys EmployeeHi Zahra,
I apologize for the delay in getting back to you. Guilin will be out of office for a while. Unfortunately, you will not be able to add files to your response. And even if you added a drive link, we are not allowed to download files from the ALF. Would you be able to share a screenhot of the mode list in the two versions? You can include the mode list as well as the "Modal Analysis" tab settings in you screenshot, like this:
Amrita -
November 28, 2024 at 11:07 am
December 3, 2024 at 7:45 pm
Amrita Pati
Thanks for sharing the screenshot. It is strange that the results are different given that the files are identical. In general we recommend the customers to rely on the latest release. But I would still like to confirm that there is no bug in the newer release in this case. I searched our database and couldn't find nay bugs specifically linked to this. Let me get my colleagues thoughts on this and then get back to you.
Amrita -
December 4, 2024 at 7:34 am
zahra mansouri
SubscriberDear AmritaÂ
Thank you for your guidance. I can send you my simulation file whenever you want. Â
Best regards.
Zahra MansouriÂ
- The topic ‘Difference between answers in version 2024 and 2017 lumerical mode solution’ is closed to new replies.
5964
1307
