May 29, 2024 at 10:00 am
Atharva Mahajan
SubscriberHello everyone,
I am simulating a solar still in Ansys Fluent to model desalination. Instead of using a collector, I want to use report definitions and expressions to find the amount of water condensing at a boundary (named "glass"). I cannot figure out how to write the expression for the same. I also want a cumulative plot and not condensate values at a particular instant.Â
Please help me out with this as soon as possibleSimulation Settings:
Multiphase model: VOF, Implicit
Radiation Model: Rosseland with Solar LoadingÂ
Flow Model: RNG k-epsilon with standard wall treatmentThank you!
June 3, 2024 at 2:41 pm
Ahmed Hussien
Ansys EmployeeThe approach for calculating the liquid volume will depend on the specific setup of your case. A few factors to consider:
- Did the domain initially contain liquid, or was it entirely vapor that then starts to condense?
If it's a condensation process where vapor is turning into liquid, you can create a volume integral report to track the volume of the liquid phase over time. This will allow you to monitor the accumulation of the liquid as the condensation occurs.
- Are you interested in the condensation happening on a specific surface?
In that case, you may want to look into using the Eulerian Wall Film model, which is well-suited for tracking liquid film formation and behavior on surfaces during condensation.
- The topic ‘Determining Volume of Condensate’ is closed to new replies.
5794
