December 14, 2023 at 3:07 pm
Emerson Buitrago
SubscriberI generated a wave in a tank wave, but now I want to plot time history of wave elevation at a specified position to be able to determine the wave height. I read on the CFX forum that the CEL to use on a Plane is:
areaInt(Water.Volume Fraction)@Area Region/area()@Area Region
This doesn't seems to work with Fluent. Can anyone help me with how to navigate this problem? Thank you. -
December 15, 2023 at 9:52 am
Forum ModeratorHave a look on here, I've posted regarding this a few times. Depth is probably a good keyword. There may also be something in the "Search Knowledge" too.Â
December 23, 2023 at 5:19 pm
Emerson Buitrago
SubscriberI have reviewed your posts, but I am still struggling to fully understand, could you provide a more detailed explanation? I am attaching images of my progress, but I am not sure if I am approaching the situation correctly.
Initially, I created an isosurface 2 with a variable x with a value of 0m. Then, I proceeded to create an iso-clip 1 as shown in the image. Subsequently, I generated the expression "minVal(y)@Iso clip 1" with the intention of using it to create the plot.
Could you please confirm if my approach is correct or provide additional guidance on how to approach this problem more effectively? I appreciate your help.
January 2, 2024 at 11:50 am
Forum ModeratorOK, you're in CFD Post, I'd post process in Fluent most of the time now.Â
OK, you've got the iso-surface on a plane, x=0. On that plane create an iso-clip of VOF=0.5 (ish, it's a guide). That should leave you with a surface that's at x=0 and is "wet". Report the max y (or z) on that isosurface, minus the mean water level. If you need a more specific location for the wave you can clip the x=0 surface by z (or y) to give a smaller zone to check.Â
January 15, 2024 at 2:01 pm
January 15, 2024 at 2:09 pm
January 15, 2024 at 2:55 pm
Forum ModeratorWhat happens suddenly if you modify damping factors? Given the value for starting point, can you check you're trying to damp the correct coordinate range?
January 15, 2024 at 3:10 pm
Emerson Buitrago
SubscriberI was guided by the text of the article where I am being guided and it says this: "The lengths of the CFD simulation domain and wave damping region are more than 7 and 1.5 times that of the wavelength, respectively."
January 15, 2024 at 3:20 pm
Forum ModeratorYes, but you're adding the damping factor at about one wave length into the domain. What happens if you alter any of the values? You also need a reasonable amount of domain that's not damped.Â
January 15, 2024 at 3:36 pm
Emerson Buitrago
SubscriberI'm going to change the star point to 5m and see what happens.Â
January 23, 2024 at 1:42 pm
Emerson Buitrago
SubscriberHello
I have finished the wave simulation, now I'm working on a similar one.Â
It is a device that moves with the waves (I use dynamic mesh) but I get a lot this message of "Floating point exception" usually when that happens to me I decrease the Time Step and it is solved (sometimes), but I do not think it is the right solution or if so? So that's why I want you to see how my meshing looks like
maximum skewness value: 0,56
Minimum orthogonal: 0.68 -
January 23, 2024 at 2:13 pm
Forum ModeratorPlease follow this thread  /forum/forums/topic/cfd-floating/ Â
January 25, 2024 at 4:50 pm
Emerson Buitrago
SubscriberHello,
I have done everything but I still can't, but when I initialize in flat if it leaves but it doesn't work like that, I need it in wavy.
any advice? -
January 25, 2024 at 6:00 pm
Forum ModeratorWaves would come from the inlet condition, I'd initialise the domain as flat as it's easier.Â
January 26, 2024 at 5:13 am
January 26, 2024 at 10:08 am
Forum ModeratorSorry, I don't understand the question. Please can you rephrase it?
January 26, 2024 at 3:15 pm
Emerson Buitrago
SubscriberI want to obtain the vertical displacement of a buoy in a wave channel, but if I initialize it in flato I can't get the results like that graph in the first 6 seconds, and in the document they initialized it with wavy.
but for some reason whenever I initialize in wavy I get "floating point exception".
the graph I sent is the results I should get.
i have already changed the mesh but i still can't.:/Â -
January 26, 2024 at 3:31 pm
Forum ModeratorWhere did you put the buoy relative to the free surface? Floating point errors tend to be associated with the solver not converging, and having the buoy partially submerged may result in it trying to regain it's neutral position too quickly.Â
January 26, 2024 at 3:40 pm
January 26, 2024 at 3:45 pm
Emerson Buitrago
Subscriberalready with the initialized wavy would be submerged 190mm
January 26, 2024 at 4:27 pm
Forum ModeratorYou may need a smaller timestep to get the model started, or to initialise from a flat free surface and then wait for the waves to develop.Â
January 29, 2024 at 5:11 pm
January 29, 2024 at 5:19 pm
Forum ModeratorDepending on how long you let the model run that could be reflection from the downstream end of the domain or just the wave not propagating (lack of time or it's being damped).Â
March 19, 2024 at 4:06 am
Alfonsa Benedict
SubscriberDear Emerson
So I'm here to ask more about your method. Did you use 2d model to simulate? If yes, what was the expression you input when you want to plot wave elevation? I'm a bit lost on this one, kindly asking for insights. Thank you in advance
- The topic ‘Determination of Wave Height’ is closed to new replies.
