February 10, 2023 at 4:57 pm
javat33489
SubscriberHi all. How to solve such a problem. Putting a steel part in acid and then putting that state of the part into static analysis and pressure?
February 13, 2023 at 1:11 pm
Ashish Khemka
Forum ModeratorHi,
Can you elaborate on what will happen when you put the steel in acid?
Ashish Khemka
February 13, 2023 at 5:39 pm
javat33489
Subscriberfor example, if aluminum is immersed in a certain acid, it will begin to oxidize and become thinner
February 14, 2023 at 4:23 pm
SaiD
Ansys EmployeeFinite element analysis method (that Ansys Mechanical solver or Autodyn solver or LS-DYNA solver uses) cannot simulate corrosion. If you can find another method/way to model the thinning of the parts due to being immersed in acid and get the final dimensions of your part, then you can simulate the effect of forces, pressures and other mechanical loads on this part in Ansys Mechanical.
Hope this helps.
- The topic ‘Details and acids’ is closed to new replies.
5824
