November 13, 2021 at 9:14 am
info
SubscriberCould you please provide us with an insight to putting dimensions on views of large assemblies with say 10000 bodies for example, without lagging?
It gets worse when working in views with "hidden line removed".
Is there a way to be as fast as putting dimensions in an AutoCad dwg file?
Thanks.
November 15, 2021 at 4:36 am
Charudatta Bandgar
SubscriberHello Evangelos Papageorgiou
The performance with subsequent releases of spaceclaim, the way it handles large assemblies has improved a lot. There are several things that decide how the SpaceClaim would behave with large assemblies. In large assemblies some times the external components could pose the lagging issue, because of additional information it has to store. Here is list of things that could be affecting how that is affected,
- Hard drive type, age/degradation, or level of fragmentation
- External file locations (e.g. local disk vs network location)
- Complexity of assembly (number and size of external components)
- Possible file inflation due to the continued use of external components. This one could be substantial. When an external component (let's name it EC) is saved within an assembly, location information for all other components from the assembly is saved within the external component and retained. Each time EC is added to another assembly and saved, more assembly information is added to EC. This can cause the file size to increase by orders of magnitude and will greatly affect performance. This problem is not uncommon. We now have a utility that will help remove this extra information. The recommended workflow is to add the external component(s) and then use Source > Internalize All to create internal copies of the component and break the link to the original file. Of course this poses the problem where updates to the master EC are not automatically applied to every assembly where EC is used, so it's not a perfect solution. The work around would be to add the ECs last before the assembly is finalized.
For assemblies with components as much as 10000, this will still be little slow. Which version of SpaceClaim are you using? 2021R2 could be better at it too. Let me know if it answers you question.
 Let me check, why this could be happening. Ideally there should not be this issue.
 Let me check with the team if there is any comparison with AutoCAD etc.
It could also be possible that the file while translating from the native format to SC, might have gotten corrupted, etc. Sometimes the constraints, relations (mirror, etc) could also cause slowing issues.
Regards.
November 15, 2021 at 8:15 am
Roberto
SubscriberCharudatta Bandgar said:
Questo problema non è raro. Ora abbiamo un'utilità che aiuterà a rimuovere queste informazioni extra. Hello Charudatta Bandgar
Could you give me this utility that clears extra information to reduce file size?
Regards
November 15, 2021 at 8:22 am
Charudatta Bandgar
SubscriberRoberto
This is already there in the new version and works in the background. I will still confirm once and get back to you.
November 15, 2021 at 8:28 am
Roberto
SubscriberCharudatta Bandgar HelloÂ
By new version, do you mean the 2022R1?
November 15, 2021 at 8:30 am
Charudatta Bandgar
SubscriberRoberto Yes, I will still confirm once.
November 15, 2021 at 9:07 am
Roberto
This is a huge improvement, if it is as you say, from the next versions there is no longer the problem that the EC files become large
Regards
November 15, 2021 at 9:55 am
Charudatta Bandgar
SubscriberRoberto Yes, will let you know after confirming.
Regards.
December 10, 2021 at 7:34 am
Roberto
SubscriberHello Charudatta Bandgar
Did you have any news?
Regards
January 10, 2022 at 4:40 pm
Roberto
Do you have any news?
Regards
- The topic ‘Detailing large assemblies’ is closed to new replies.
5824
