Designing WPT coils using ANSYS Maxwell,I want to observe behavior of coils with changing frequency?
March 10, 2020 at 1:18 pm
tejprathapganji
SubscriberI am designing WPT coils using ANSYS Maxwell, I want to observe the behavior of coils with changing frequency? where is the option to change the frequency? in magnetostatic or transient mode. Kindly help me out, Thnks.Â
Viewing 0 reply threads
- The topic ‘Designing WPT coils using ANSYS Maxwell,I want to observe behavior of coils with changing frequency?’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1256
1118
1015
