July 31, 2020 at 5:38 pm
prajput
Ansys EmployeeHello, what emission characteristics do I need to look for when designing a high speed board?
Thank you.
July 31, 2020 at 5:39 pm
CB
Ansys EmployeeHi - If your board is inside a metal housing then the far field emissions may not be important. The near fields above the board traces are important as they may cause some parasitic coupling to other parts of the board or to the housing itself.
prajput
Ansys EmployeeWill vias effect my design?
CB
Ansys EmployeeHi - Yes vias will impact your design, especially at the higher frequencies. Another important question is how are the vias designed - is it a single via or an array of vias. Is the transmission line a single signal trace or is it a pair of transmission lines - common or differential mode?
- The topic ‘Designing high speed board’ is closed to new replies.
Ansys Innovation Space
1208
1092
1068
952
