November 1, 2021 at 11:16 am
jp_jason
SubscriberHello Ansys community
I would like to build a fiber composite model with the help of ACP. The layers shall be parallel to the bottom side and cut off at the edge of the part . Thus I imported a shell-layer of the bottom side of the model. The Image underneath represents the disired layer- and geometry-buildup.
November 3, 2021 at 3:21 pmjp_jason
SubscriberFound the solution. Use a shell geometry at Cut-Off geometry Selection Rule (with a Solid geometry it didn t worked). During the creation of plies, insert the Cut-Off Solution at Rules.
November 4, 2021 at 12:51 pmKarthik Remella
AdministratorExcellent! Thank you for sharing the solution.
Good luck!
Viewing 2 reply threads- The topic ‘Design of a cut-off layer geometry with Ansys-ACP’ is closed to new replies.
2863
970
851
599
591
