3D Design
3D Design
Design Modeller Fill problem
    • emma
      I am a new user so apologies for the elementary question! I am using Design Modeller to generate a 3D model, I want to be able to model fluid flow through the annulus of a pipe which also has two other smaller pipes within it (attached powerpoint explains better).  I want to Fill the annulus around the two internal pipes so I have a body to mesh for the fluid annulus but I am having problems. I created the 3 pipes using the Primitive shapes (cylinders) and created a surface at each end of the large pipe but I cannot get the Fill to work?
      Thank you for any help you can give!
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Subashni Ravichandran
      Hello Emma at Resolute
      This Forum is meant for dedicated support of Ansys Discovery Products: Discovery SpaceClaim, Live and AIM.
      I would recommend you to seek support for your query on Ansys Design modeller from Ansys Customer Portal.
      • emma
        Subashni  thank you! I will try on the other forum :)
  • The topic ‘Design Modeller Fill problem’ is closed to new replies.
