May 25, 2020 at 7:38 pm
jtalaman
SubscriberHello,
I'm sure this has been asked before, however, I have not been able to find a suitable answer. While importing a STP file into the Design Modeler, I was given the warning "Self Intersecting Geometry" I have imported this same file a few times, sometimes without issue. As I proceed into the Mesh window, this seems to present problems. Any idea how to fix this?
I have included the Design Modeler file. Thanks!
May 26, 2020 at 12:57 am
May 26, 2020 at 11:52 pm
jtalaman
SubscriberWell, that's interesting, This model shouldn't be that large. We've had this problem before where the file seems to be the correct size in one software used to create the step file, then we import to the design modeler and bang, it's 1.0 meters in diameter. The units should be in SI. This shouldn't be more than 40 mm in diameter.
- The topic ‘Design Modeler: Self Intersecting Geometry’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
4597
1495
1386
1209
