March 28, 2019 at 8:13 pm
ansysuser
SubscriberI am trying to generate a surface from a sketch. I made a rectangle, then trimmed the top edge and drew lines to create a smaller rectangle on top of it. I created a surface from a sketch just fine, but then when I went back and filleted the inner corners it now says an error:
"No Closed Profiles"
It is clearly closed. What is going on?! I have attached the DM database.
March 28, 2019 at 11:41 pm
peteroznewman
SubscriberLook at the Details View of the Sketch. There are three Circular Arcs. But you only have two fillets in the profile. Therefore there is one closed profile with two fillets and one open profile of a circular arc in the sketch Get rid of the extra circular arc from this sketch and it will work.
March 29, 2019 at 4:25 pm
ansysuser
SubscriberThank you. I have no idea how that arc got there, but now I know what to look for in the future. I appreciate your response.
August 11, 2021 at 2:54 am
August 11, 2021 at 3:08 am
December 17, 2022 at 11:07 am
chaochao.wang
SubscriberI met the same problem, have you solved this? -
January 31, 2023 at 7:50 pm
Alejandra Francisco
SubscriberHas it been solved?
November 8, 2023 at 8:30 am
Mikelis Dzikvics
SubscriberI tried using some constraints like parallel and symmetry on some lines and it fixed it for me. I guess they look closed and parallel but potentially are slightly off.Â
- The topic ‘Design Modeler says no closed profiles, but it is closed’ is closed to new replies.
