May 12, 2024 at 12:45 pm
NVN NAMMA
Subscriber1. As Part of an AQWA simulation, while modelling 1000 m pipe in design modeler, unable to form single line elemnt. Then i tried with 10 line sketches and still while forming line from sketches, it is taking only up to maximum 500m. why is it so?Â
2. One more issue that I faced is while extruding large distance it was not taking. for example 10 m dia pipe 1000 m length. unable to model the same as line element also.Â
May 13, 2024 at 3:03 pm
mrife
Ansys EmployeeHi Nasma
DesignModeler has an default limit of 1 km 'bounding box' where are geometry has to be within this box. So that is +/- 500 m in each x/y/z direction. Which is why it fails to extrude more that 500 m in one direction.
In Tools -> Options; Units you can turn On the 'Large Model Support' which changes the bounding box to I think 10 km sides; 1000 km^3 total volume if I remember correctly.
Mike
May 30, 2024 at 4:34 pm
NVN NAMMA
SubscriberDear Mike..
thanks for your reply. After changing to large model support i am unable to create 100o pipe, as a diffracting body it is taking 500 m only. as a line body also same. I wonder how people model such large structures in deep water
here before extrusion
after generating
when i tried as a line body, it is taking only 500 m
kindly help with this
May 30, 2024 at 5:11 pm
mrife
Ansys EmployeeNasma
Check the menu -> Units -> Large Model Support; make sure this is checked 'ON'. Prior to creating any geometry. I just tried in 2020R1 and it works for me (am able to create a 2000 meter line).
August 17, 2024 at 8:38 am
NVN NAMMA
SubscriberThank you for the response. I did that option while creating the model.Will check once
October 29, 2024 at 6:48 am
NVN NAMMA
SubscriberThank you. It worked for me. Only thing change the settings well before creating the geometric model
- The topic ‘Design Modeler-, model a 1000 m pipe, w’ is closed to new replies.
5894
1306
