December 21, 2018 at 4:11 am
ashiadarsh
SubscriberCan we assign a body as frozen to the imported CAD geometry in ANSYS Design modeler?
December 21, 2018 at 4:18 am
December 21, 2018 at 5:46 am
ashiadarsh
Subscribermy body is split into two...i want only one part to be add as frozen...Is it possible?Thank you the reply
December 21, 2018 at 6:11 am
Keyur Kanade
Ansys Employeeuse tools - freeze.Â
it will freeze everything.Â
then use tools - unfreeze to unfreeze required bodies.Â
if this helps you, please mark this post as 'is solution' to help others on forum.
December 21, 2018 at 6:36 am
ashiadarsh
SubscriberOk that helped...but when we go for meshing contact regions are showing...how to establish connections between the two domains?
December 21, 2018 at 6:46 am
Keyur Kanade
Ansys Employeeyou will do that in fluent.Â
December 21, 2018 at 7:04 am
ashiadarsh
Subscriberyou mean defining Mesh Interfaces in ANSYS FLUENT?
December 21, 2018 at 7:29 am
Keyur Kanade
Ansys Employeeyes
May 8, 2021 at 4:58 am
Randhir
SubscriberSir, how we can define mesh interface between two solids and then between fluid and solid for the same geometry?
May 9, 2021 at 10:54 am
Ram Gopisetti
Ansys EmployeeHi Array,
for fluent only you can do the following
Any contacts that were detected in the meshing in connection group will be automatically imported into fluent unless you modified them ,you can also define manual contact between faces or entities , thus applies to any bodies irrespective of type (solid or fluid) and this contacts are shown in mesh interface node of fluent tree..
Therefore, you need to make sure you have defined contacts and if you are need heat to be transferred make sure you make contacts as coupled.
Cheers, Ram
Viewing 9 reply threads
- The topic ‘Design Modeler?’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
1493
1375
1197
