June 23, 2023 at 7:33 pm
javat33489
SubscriberHi all. Is it possible in material design to create a composite of randomly shaped particles, such as chip flakes. To have a matrix and chip flakes? Thank you.
June 29, 2023 at 1:46 pm
ashish.khemka
Forum ModeratorHi,
Please see if the following link helps you: How to Simulate and Design the Microstructures of Composites | Ansys
Ashish Khemka
June 29, 2023 at 4:57 pm
javat33489
SubscriberYou did not understand me! I know all these courses. That's why I'm asking, is it possible to make a composite from a polymer and wound broken particles such as metal shavings?
June 29, 2023 at 5:41 pm
Reno Genest
Ansys EmployeeHello,
You can have random spherical particles (both size and position) using the “Random Particle” RVE:
Or, if you need different particle shapes, you can try creating your own RVE using the User Defined RVE:
You will find more information about User Defined RVE in the help:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/acp_md/acp_md_user_defined_RVE.html
Let me know how it goes.
Reno.
August 4, 2023 at 7:21 pm
javat33489
Subscriber>>Or, if you need different particle shapes, you can try creating your own RVE using the User Defined RVE:
but you cannot create your own particle geometry or import another one there
August 4, 2023 at 8:12 pm
Reno Genest
Why not? With a User Defined RVE, you can create your own geometry.
Reno.
August 5, 2023 at 10:20 am
javat33489
SubscriberI also thought so, but there are no tools for drawing and you can’t import geometry
- The topic ‘Design materials and composite’ is closed to new replies.
