June 25, 2023 at 12:09 am
SilverRD
SubscriberHello,
May I kindly ask for your help. I am doing a simulation for an ejector the details are...
Solver: Density based.
Model: Transition SST (4 eqn)
Material properties: R1234ze (Density, Cp, thermal conduction, viscosity > real gas - nist).
Formulation: Implicit
Flux Type: Roe-FDS
Spatial Discretization
Gradient: Least Squares Cell Based
Flow: Third-Order MUSCL
Turbulent Kinetic Energy: Third-Order MUSCL
Specific Dissipation Rate: Third-Order MUSCL
Intermittency: Third-Order MUSCL
Momentum Thickness Re: Third-Order MUSCL
do i need to run the simulaiton more than 42250 times?
June 26, 2023 at 7:16 am
SRP
Ansys EmployeeHi,
I suggest you to try FMG initilization. Flow convergence can be accelerated if a better initial solution is used at the start of the calculation. The Full Multigrid initialization (FMG initialization) can provide this initial and approximate solution at a minimum cost to the overall computational expense. other you can try using real gas property table (RGP).
You can refer to fluent user’s guide for more on FMG initilization: 33.10. Full Multigrid (FMG) Initialization (ansys.com)
Thank you
June 27, 2023 at 11:42 am
SilverRD
SubscriberHello! Is there any way to open the link you provided?
June 27, 2023 at 11:58 am
SRP
Ansys EmployeeHi,
Please refer to this forum discussion: Using Help with links (ansys.com)
Hope this helps you.
Thank you.
June 30, 2023 at 10:06 am
July 13, 2023 at 9:20 am
SRP
Ansys EmployeeHi,
Such error mostly occur due to bad mesh. Can you please share your mesh statistics?
Thank you.
- The topic ‘Density Solver – Ejector’ is closed to new replies.
5979
1307
