August 13, 2024 at 8:10 pm
Leon15
SubscriberHello, following some recommendation on this forum, I am trying to use the EMOD command to create elements with an higher order only in one direction for a transient thermal simulation. As a test, I tried deleting all the mid nodes on elements (solid279) using the following commands:
MODMSH,DETACH
EMID,REMOVE,ALL
However, it is not doing anything. Am I missing something? Can the EMODIF command be helpful in this case?
Thank you
August 14, 2024 at 2:35 pm
dlooman
Ansys EmployeeThe simple test below works for me.
/prep7
et,1,279
block,,1,,1,,1
esize,1
vmesh,1
modmsh,deta
emid,remove,all
elist Âelist output:
ELEM MAT TYP REL ESY SEC Â Â Â Â NODES
    1  1  1  1  0  1    2   6   4   1   9   10   12   14
                 0   0   0   0   0   0   0   0
                 0   0   0   0Â
August 14, 2024 at 3:04 pm
Leon15
SubscriberÂ
Hello,Â
Thank you for the quick reply. I was using the graphical interface (Plot, Nodes) to verify the effetiveness of the command, but in the GUI the mid nodes still appear even though they have been deleted (I assume it is because the elements are still labeled as solid 279). However, using the command ELIST did show that indeed the mid nodes had been deleted. Â
Cheers,
Leon
August 14, 2024 at 3:28 pm
dlooman
Ansys EmployeeYou could delete the unused mid-side nodes:
After emid command:
nsle,u    ! unselect nodes used by elements (corner nodes)
ndele,all  ! delete unused mid-side nodes
allsel
5824
