TAGGED: ansys-workbench, apdl, mechanical-apdl, modal-analysis
January 14, 2022 at 1:51 pm
BassaSelim3
SubscriberHI,
Is there an APDL command which does the same as "delete unneded files" in the analysis settings?
January 17, 2022 at 1:22 pmAshish Khemka
When the Delete Unneeded Files property is set to Yes (default), the application automatically executes the Mechanical APDL command /FCLEAN. This command deletes all of the unneeded distributed files from the scratch directory when performing a distributed solution. This action eliminates the need to download potentially large distributed files, and as a result, completes your solution faster.
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘Delete unneded files in APDL’ is closed to new replies.
3139
1007
918
858
792
