delete-material: still in use by surface_body.
    • mohamed.elfaham
      I am trying to remove " Air " from the list of materials but I got this error " ethyl alcohol"
      I am working on two phase flow simulation, So primary phase I chose liquid ethyl alcohol, Secondary phase I chose ethyl alcohol, even the solid is Aluminum.  I check cell zone conditions and boundary conditions and Air doesn't exisist.
      How I can delete " Air" ?
    • Murari Iyengar
      Please check if air is being used by any Cell Zone regions. You can go to Cell Zone conditions and under the fluid domains, check which material is being assigned.
  • The topic ‘delete-material: still in use by surface_body.’ is closed to new replies.
