September 15, 2021 at 6:52 am
cbur
SubscriberGood morning,
Some of our customers have a problem with the parametric sketch: it is impossible to delete a sketch dimension with the "delete" key or with the constraint suppression tool.
Have you ever encountered this problem? Is there a solution?
Because it makes the parametric sketch unusable.
Regards
September 15, 2021 at 8:34 am
Charudatta Bandgar
SubscriberHello charlie
We have not come across such issue, is it specific to files or happens with any parametric sketch. Could it be possible to share an example of what issue they are getting, are they getting any error message?
Regards.
September 15, 2021 at 8:49 am
cbur
SubscriberHello,Charudatta BandgarÂ
This is not related to a file, it happens as soon as you open SC. and no error message appears. only an error sound. I will ask the client to share a video as soon as possible.
September 15, 2021 at 9:16 am
September 17, 2021 at 4:19 am
Charudatta Bandgar
Subscribercharlie I have filed a bug ticket (521744) to understand from the developers what could the issue be, I will get back to you as I hear back from them.
Regards.
October 1, 2021 at 8:50 am
Charudatta Bandgar
Apologies for the delay, I heard back from the developers. We were not able to reproduce this on our end, though the French UI could be an issue. We changed the SC language to French to see if it is reproduced likewise, with no luck. Unless it can be reproduced, there isn't a way to pinpoint to the reason behind this behaviour. One possibility could be that the OS's language itself is an issue, that I am yet to try with my colleague with French language. Will it be possible for you to share the logfiles of this particular session? If not we will have a meeting with the customer and see what could be the issue, I will involve the developers as well.
Regards.
October 4, 2021 at 9:03 am
cbur
SubscriberHello, Charudatta Bandgar I enclose the log file with the problem! This file comes from the computer of my colleague who has the same problem as some of our customers. So if you need more information, don't hesitate! Regards? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 4, 2021 at 9:51 am
Charudatta Bandgar
SubscriberThanks, charlie I will forward the files to the developers, let see if we can figure out a reason.
Regards.
- The topic ‘delete a quotation in a parametric sketch’ is closed to new replies.
