February 25, 2023 at 1:10 pm
Mahmoud Mosaad
SubscriberGood morning everyone!
I'm working on a bachelor project and need to simulate a delaminated carbon fiber composite. I need to determine the effect of delamination on the behavior of the composite and I don't know how to model a composite with delamination. Can anyone help me with this problem??
Thanks in advance! -
February 27, 2023 at 11:59 pm
Reno Genest
Ansys EmployeeHello Mahmoud,
As a first step, you could evaluate the risk of delamination using a failure criteria such as Puck 3D. See the ACP documentation for more informaiton:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/acp_ug/acp_compmodel_compfailure.html?q=delamination
If you want to explicitly model the delamination and have ply separation, you could do this using interface layers in ACP:
Here is more information from the ACP doc:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/acp_ug/acp_ug_interface_layer_properties.html?q=delamination
If you have access to the Ansys Learning Hub (ALH), you will find a workshop on delamination in the following training course:
https://jam8.sapjam.com/groups/YHNivy2FbzTCwBmZhqlMGS/documents/dPAyVTKlaMzI1pyYEXtaKs/slide_viewer?_lightbox=true
Let me know how it goes.
Reno.
February 28, 2023 at 1:23 pm
Mahmoud Mosaad
SubscriberThanks a lot, Reno ! Actually, I don't have access to Ansys Learning Hub but I will follow the steps you mentioned. I just have a final question, can I specify the delamination region ?? since I don't need the delamination to be through the entire sample. Thanks a lot for your time and consideration !
- The topic ‘Delamination interface in ACP’ is closed to new replies.
