July 23, 2024 at 11:46 am
Arman Alizadeh
Bbp_blockedHi,
I generated a 'part' using ''Design Modeler'' and I wanted to set the total Mass as a parameter in Mechanical Application. I found a thread here that used a python code. But I could not use it to calculate the total mass and determine the output parameter. i have a Ansys 2024 R1 Student Version.
July 25, 2024 at 4:54 am
July 26, 2024 at 2:47 am
mjmiddle
Ansys EmployeeWhat kind of analysis are you doing? Materials deform during analysis but unless you are doing a wear type analysis or purposefully EKILLing elements, the mass will stay the same.
- The topic ‘Defnition total Mass as a Output Parameter in Ansys Mechanichal Application’ is closed to new replies.
