September 20, 2023 at 2:06 am
Christopher Curry
SubscriberHi,Â
I am new to ANSYS workbench and I am trying to model a material not contained in ANSYS software by an experimental density and Poisson ratio. The Young's Modulus value changes based on the x-position of the model. Is there a way I can have Young's Modulus value change based on a position? I have only been able to change it based on Temperature and cannot figure out how to change it.Â
Thank you!
September 20, 2023 at 2:32 pm
Sampat Kumar
Ansys EmployeeHi Christopher,
You can check the attached help documents that will help you add the field variable in the Engineering data.Â
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_eda/eda_field_variables.html?q=field%20variable
SampatÂ
September 20, 2023 at 2:38 pm
Christopher Curry
SubscriberHi Sampat,
Thank you for the quick response. I am having trouble accessing the link as it will not allow me to sign in for the support space as I have my license through my university. Is there another way to view the link?
September 26, 2023 at 12:05 pm
Sampat Kumar
Ansys EmployeeHiÂ
I appreciate your patience.Â
please go through the following method to view the documents and sign in there.ÂHere's how you can access the Ansys Online Help from within the Ansys Student products:
- Open Ansys Workbench (or any other Ansys product) and go to Help > Ansys Workbench Help. A browser window will open.
- Copy the link to the Ansys Online Help from the post on the Ansys Learning Forum.
- Paste the link into the address bar of the browser window opened in step 1, and you'll be able to access the desired page
Please follow the following link to see how to sign in to see the help documents. Please let me know if you have any questions here.Â
Sampat
- The topic ‘Defining Young’s Modulus based on x-Position’ is closed to new replies.
6219
