August 1, 2019 at 3:23 am
hamda
SubscriberHello,
I am working on a problem in which mass flow rate is constant. I specified mass flow rate in "inlet" boundary condition. But after seeing the results (velocity and density) I realized that the mass flow rate wasn't constant. It should be mentioned the fluid is helium and it is considered as an ideal gas. Now I was wondering how I can define mass flow rate as a constant value into pre CFX or if I can't do that, How can I define velocity or density as a function of each other to keep mass flow rate constant.
Many thanks in advance -
August 1, 2019 at 11:11 am
Forum ModeratorCheck the flux on the boundary: if the model is converged it'll be as you set. I suspect you've not accounted for something when doing the velocity & density maths.Â
August 1, 2019 at 7:36 pm
hamda
SubscriberI think maybe the mass flow rate area (A) is not constant in my geometry. As you see fluid should pass through these spheres but A would be the same at inlet and outlet but the value of (density *velocity) is not the same for both. in Boundary conditions : I selected "as specified" for mass flow rate area and then I changed into "total for all all sectors" but I didn't see any difference.
August 2, 2019 at 10:51 am
Forum ModeratorI assume you mean it flows between the spheres? Monitor the inlet mass flow & outlet mass flow: are they equal and are they what you expect?
- The topic ‘Defining velocity as a function of density’ is closed to new replies.
5969
1307
.jpg?width=690&upscale=false)
