June 20, 2018 at 8:58 pm
masud407
SubscriberI can define the properties of materials in ANSYS workbench. However, if my material is nonlinear, do I need to define anything extra? Generally I put density, poison ratio and young's modulus to define the material properties.
June 20, 2018 at 9:41 pm
peteroznewman
SubscriberYes, you drag and drop the needed nonlinear model from the Toolbox onto your material, then enter the material constants that model needs. The list of nonlinear models is grouped into types. I have expanded the Hyperelastic and Plasticity models, but there are many more. The challenge is obtaining the correct experimental data for the material constants and coefficients.
August 24, 2019 at 6:58 am
Hoosein86
SubscriberHow can we find material constants and coefficients ? could you please show what exactly you mean?
thank you
August 24, 2019 at 10:52 pm
peteroznewman
Subscriber@Hoosein86,
You have opened your own discussion here.
Don't use this discussion, it has been Solved and it is not your discussion.
You can ask about this discussion by using a link to it from your own discussion.
Please don't ask any more questions here.
- The topic ‘Defining nonlinear material properties in ANSYS workbench’ is closed to new replies.
5824
