September 12, 2021 at 3:18 pm
Alp
SubscriberHi,
How can you use multiple moving heat source together? I will be happy if you share the parameters of it.
Here you can find the parameters.
September 12, 2021 at 5:20 pmSeptember 13, 2021 at 1:32 pmAlp
SubscriberOK I solved the issue. However, I wonder is there any way of creating loop instead of creating many moving heat flux?
February 3, 2022 at 1:10 ammkalel
SubscriberHello Alp,
How did you able to find out the template of the code for moving heat flux . i tride to work on your code with my model it didn't work.Can you help me how you able to fix ?
Viewing 3 reply threads- The topic ‘(Defining more MOVING heat flux)How can you use multiple moving heat flux?’ is closed to new replies.
5709
