Defining liquid viscosity using temperature dependent polynomial – Fluent
    • Waruna Maddumage
      I'm trying to define viscosity of a liquid as a temperarture dependent polynomial function in Fluent.
      I plotted the experiment data in Excel to get the trend line and polynomial equation. Below is the Excel polynomial graph and function.
      When I tried to enter the coeffients in Fluent to define viscosity, I get a completely wrong graph.
      Below is the graph I got from Fluent to the coeffients from the above equation.
      Can someone pls tell me what I am doing wrong here?
      Thanks in advance,
      Best regards,
      Waruna
    • abhnv11295
      I would suggest you to kindly cross-check manually with the coefficients you have obtained via Excel.
      • Waruna Maddumage
        Thanks, your suggestion helped.
        Increasing the significance of the coefficients solved the issue. Using Matlab polyfit is the better choice.
    • Amine Ben Hadj Ali
      I came across similar issues several times. The same reason: the significance / number of digits / accuracy.
  • The topic ‘Defining liquid viscosity using temperature dependent polynomial – Fluent’ is closed to new replies.
