Defining custom material based on ASME BPVC Div. 2
    • sna
      Hi!
      I'm new to Ansys, and i'm in the process of defining a new material in Workbench (Engineering Data)
      When defining a new metal, should i base all input on true stress/strain? or use engineering stress/strain?
      Should the "Tensile Yield Strength" be based on the 0.2% offset?
      Thank you!
      Regards
      Siggi
    • armin.abedini
      Hi Sigurd, You should use plastic strain versus true stress to define the hardening (stress-strain) curve of your metal. Initial yield stress (0.2% rule) and ultimate tensile strength are commonly defined based on engineering stress.
