August 1, 2019 at 6:59 am
Chris1opher
SubscriberDear all,
I am modeling a mixture in a closed reactor so that the volume can not change. As mass conservation applies, the density can not change.
It is not possible to choose [constant] as the density property of my mixture, when I define the physical properties of the mixture. As a workaround, I could use a mixing law and use the same density for each pure component. I wonder if there is a reason that I cannot choose [constant] as the density property for my mixture.
Kind regards.
Christopher
August 5, 2019 at 2:17 pm
Forum ModeratorIf you're in Fluent check the density for each/all of the materials - are any variable? I'm pretty sure you can set a constant for a mixture density.Â
August 5, 2019 at 2:36 pm
August 5, 2019 at 3:29 pm
Forum ModeratorAnd what are the densities of the various mixture materials?Â
August 5, 2019 at 3:35 pm
Chris1opher
SubscriberI want my mixture to have always the same density no matter of the composition.
The density is 1042 kg/m^3
When I'm specifying the viscosity of the mixture as constant I'm no longer able to edit the viscosity of the pure materials. I was expecting that the same thing works for the density.
August 6, 2019 at 11:12 am
vinitraj3
SubscriberFor that you need to define the density of each component of mixture as 1042 kg/m^3. Then in the mixture panel you can specify the density as volume weighted mixing law. It will always return 1042 as the density of mixture
Regards
Rajeev
August 6, 2019 at 12:19 pm
Chris1opher
SubscriberDo you know why there is no possibility to set the density of the mixsture as constant like it is possible for other proberties?
August 6, 2019 at 12:46 pm
Forum ModeratorThere's probably some maths that needs a mixture value. Normally we'd use ideal gas for a sealed system where heat was expected otherwise you'll miss any buoyancy effects.Â
- The topic ‘Defining constant density for mixture’ is closed to new replies.
5899
1306
