TAGGED: #, anisotropic, ansys-workbench, apdl-commands
September 20, 2022 at 6:16 pm
Emre YILDIRIM
SubscriberHello everyone,
I am trying to define anisotropic elasticity using stiffness matrix of laminated structure in Workbench. However I encounter error saying "Material 1 should not have both an ANEL material matrix and EX defined." How can I solve this issue?
The code I wrote in workbench command line can be seen in the figure.
September 22, 2022 at 12:41 pm
Ashish Khemka
Forum ModeratorHi @Emre,
The source of error is due to the existing default material properties assigned by Workbench is not overwritten. By default, WB assigns isotropic elastic material properties to the part, and even if one assigns a set of anisotropic material properties, the old linear elastic isotropic properties don't get disabled, hence the conflict.
Ashish Khemka
- The topic ‘Defining Anisotropic Elasticity as Elastic Coefficient Matrix’ is closed to new replies.
5824
