LS Dyna
LS Dyna
Define user_derfined_viscosity MAT_SPH_VISCOUS
    • WooMin Jang
      Hello i'm a master student developing user material.
      i'm wondering that how can i define user- derfined viscosity in mat_sph_viscous subroutine in package..
      1) Is it possible to link my umat41v with subroutine f3dm9sph_userdefin?
          I want to define the material that is solid when elastic and fluid when after yielding
      2) In subroutine f3dm9sph_userdefin, is the xmu is the variable to define??
           i can't understand that there's no example in the package...
      I really appreciate your help...
      please help me
    • Ushnish Basu
      Dear WooMin,
      You can use DEFINE_ADAPTIVE_SOLID_TO_SPH to transform a solid element to an SPH particle, though the material properties will be taken from the original solid element.
      If you want your material to behave more like a fluid after yielding, you can just define it appropriately in the material routine itself, no need to call a separate routine.
      f3dm9sph_userdefin is called from within MAT_SPH_VISCOUS, and it;s not meaningful to call it from elsewhere.
  • The topic ‘Define user_derfined_viscosity MAT_SPH_VISCOUS’ is closed to new replies.
