Preprocessing
Preprocessing
Define the input workbench parameter as precalculated output
    • Deus Ex Machina
      Hello everyone, I am trying to define as input workbench parameter another output parameter in the same workflow (obviously another previously calculated case)nFor example: if I have output parameter P01 = 5, I want to use it in P07 as input parameter P07=P01. Right now I copy and paste, but I have about 100 points.nHow can I do this?nThank you very much.n
    • Keyur Kanade
      I think this can be done through WB scripting. Please search on WB scripting on this forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • ramgopisetti
      How about you type expression say for all Parameters . For all 100 parameters you can just type P01 in the expression field , it automatically copy the respective values into all parameters, so you left with one parameter to tune there after. nThat Said, you can use OPTISLANG Optimisation tool to bulk select the parameters and use the expression and it will applu to all selected parameters as follows nCheers,nRamn
    • Deus Ex Machina
      How about you type expression say for all Parameters . For all 100 parameters you can just type P01 in the expression field , it automatically copy the respective values into all parameters, so you left with one parameter to tune there after. https://us.v-cdn.net/6032193/uploads/PHGW2VYWUZ65/screenshot-2879-29.pngThat Said, you can use OPTISLANG Optimisation tool to bulk select the parameters and use the expression and it will applu to all selected parameters as follows https://us.v-cdn.net/6032193/uploads/3SAH1EEPF6KX/image.pngCheers,Ram/forum/discussion/comment/108247#Comment_108247
      Thank you very much, that's what I was looking for.n
    • ramgopisetti
      Thank you can you please make mine as answred in your side.nRam n
Viewing 4 reply threads
  • The topic ‘Define the input workbench parameter as precalculated output’ is closed to new replies.
