October 31, 2023 at 4:43 pm
Ramesh Chandra Mishra
SubscriberHi
I am writing a UDF to specify the source term but not using any zone ID, rather I am using co-ordinates of the zone in my code which is as follows:
DEFINE_SOURCE(Pollutant_3, c, t, dS, eqn){real x[ND_ND];real source;C_CENTROID(x, c, t);Âif (x[0] >= 111.0 && x[0] <= 123.0 && x[1] >= 0.0 && x[1] <= 0.45 && x[2] >= 90.0 && x[2] <= 126.0) //Modify the release source mzhang{source = NO2;}else{source = 0;}ÂdS[eqn] = 0;return source;}So do I need to mention about the same in my GUI too and if yes where, because i dont have a zone where i can specify these details. -
October 31, 2023 at 5:08 pm
Forum ModeratorYou still need to hook the UDF into the cell zone(s), it's covered in the manual. I'm assuming NO2 is defined somewhere?Â
As a more general comment, if source is REAL define it as 0.0Â Â It shouldn't cause any problems but is something I've always been pulled up on.Â
November 1, 2023 at 4:15 am
SubscriberHi Rob
Just want to confirm if you are saying I should initialize source to 0.
Secondly, my initial query , I don't have a cell zone in my mesh, that is the reason I was defining it in UDF. If you say that hooking UDF is mandatory, so I am thinking of creating a region and then initialize and patch the user defined source. Will that work? I mean will it take the patched pollutant as the source term?
November 1, 2023 at 5:17 am
SubscriberRob
Apart from the above query, I am facing one more issue. I need to run this simulation on a cluster. So how will this patching work? Because UDF compilation has to be done on a cluster. And without compiling and initializing , I can't patch the source to the region. Can we do it through TUI commands in journal file.
If yes, can you please let me know the commands.
November 1, 2023 at 10:29 am
Forum ModeratorA source term is a continuous addition (or removal) of something from a cell zone in the model. A patch is a one off value added (typically) at the beginning of the run.Â
If there is no cell zone you can't interact with it as there isn't anything to interact with - Fluent needs the mesh to know there's something there!Â
- The topic ‘Define source term in udf without using zone ID’ is closed to new replies.
3572
1188
1076
1063
952
