LS Dyna
LS Dyna
define material mass density variable with loading process
    • stringinging000
      How can I use UMAT subroutine to define a material whose mass density varies with the loading process?
    • Ushnish Basu
      The current density is available in common block aux35loc (search dyn21*.F), but I don't think it can be changed in a way that will affect the mass calculation. Moreover, I don't think it's possible to access loading conditions from the user material routines. So I don't think it is possible to do what you are looking to do.
    • stringinging000
      Thank you, is there any other way to implement this feature?
  • The topic ‘define material mass density variable with loading process’ is closed to new replies.
