February 29, 2024 at 12:23 pm
guan shengyi
SubscriberHi all
I am trying to use an UDF to define mass diffusion coefficients for fluid in the system.
I am attempting to redefine the fluid diffusion coefficient using `DEFINE_DIFFUSIVITY`, but I am encountering issues. My goal is to modify the diffusion coefficient based on a pressure condition using a scaling factor, and I am using `C_DIFF_EFF(c,t,i)` to retrieve the diffusion coefficient. However, when storing this value in a User-Defined Memory (UDMI) variable, it remains 0. Can you help me identify the issue? Below is my UDF.
DEFINE_DIFFUSIVITY(DD, c, t,i)/*two-phase fluid*/
real Kg;/*diffusion coefficient*/
if (C_P(c, t) < 20e+05)
Kg = 10e-20*C_DIFF_EFF(c, t, 1);
else if (C_P(c, t) > 20e+05)
Kg = C_DIFF_EFF(c, t, 1);
C_UDMI(c, t, 0) = C_DIFF_EFF(c, t, 1);
return Kg;
March 4, 2024 at 12:38 pm
SRP
Ansys EmployeeHi,
I suggest you to initialized kg to zero and try to store the modified kg in UDMI.
- The topic ‘define mass diffusion coefficients for porous media and multiphase’ is closed to new replies.
