Platform
Platform
Topics related to optiSLang, HPC, DesignXplorer, Cloud and more.
Define contacts by a specific rule
    • Mo
      Hi all,
      I have a model which has more than 600 contact pairs. Is there any way in ANSYS Workbench 2022 to find the contact pairs with contact areas more than x amount to select them and change the type of connection? I cannot go through all 600 connections to define the contacts one by one.
      thanks
    • Ashish Khemka
      You can create a named selection of areas of interest based on a range of areas, then use an object generator to define the contacts.
      Named Selections (ansys.com)
      Be More Productive Using Ansys Mechanical | Ansys Course
      How to access the ANSYS Online Help
      Ashish Khemka
    • Mo
      Hi Ashish,
      Please have a look at the attached file. As the contact areas Target and Source are same size, I'm unable to implement your advice. could you please have a look. ANSYS Workbench I'm using is 2022 R2
    • Mo
      No thoughts on this? if I select target and source as same it defines 6 contacts as below:
    • Ashish Khemka
      Even, if the contact and target are the same size they will be categorized into different named selections. Say one named selection contains all the contact sides and the other named selection contains the target side and then use the object generator.
      Ashish Kumar
    • Mo
      if I name select based on the area, all the areas with the same size will be selected as one Name Selection. Right?
      Then, when I want to do use object generator just one name selection will be showed up on the object generator Target and Contact.
      Please advise. thanks.
Viewing 5 reply threads
  • The topic ‘Define contacts by a specific rule’ is closed to new replies.
