July 9, 2021 at 11:50 am
Rameez_ul_Haq
SubscriberFor all the contacts (Non-Linear as well as Linear), I see an option of penetration convergence tolerance and also normal stiffness of the contact. I want to know the default values used by the solver for each of these, and for each of the contact.
I am asking this because sometimes, my solution is unable to converge at the contact region and I want to play with the Penetration Convergence Tolerance and Normal Stiffness values in order to make it converge. However, if I randomly input a very high or very low value, then the solution results might not be accurate at all.
Moreover, does the penetration convergence tolerance also needs to be met for the solution to converge at the contact region even if I am using a linear contact?
July 13, 2021 at 7:39 amRameez_ul_Haq
Subscriber, I would be glad if I could get help on this one please?
July 13, 2021 at 12:55 pmEmperor
I asked myself this question not long ago. If you look at this link "Table 3.1: Summary of Real Constant Defaults in Different Environments" there are default values. You can change them with the 'RMODIF' command that I use a lot since this discovery
July 14, 2021 at 7:52 amRameez_ul_Haq
Subscriberthank you for navigating me through that table. So it means that we shouldn't input any value manually, we should only play with the factors for normal stiffness and penetration convergence tolerance since we still don't know the value used by ANSY but we just know the default factors.
July 15, 2021 at 6:59 amEmperor
Subscriberyes I often played with the different factors for the normal stiffness. For penetration some formulation accept penetration as the increased Lagrange and pure penalty formulation. Others do not accept penetration as Normal Lagrange. So in case you choose for example a Normal Lagrange formulation you will not have to enter a value for penetration.
Let me show you the pictures below to illustrate what I am saying:
July 15, 2021 at 12:30 pmRameez_ul_Haq
Subscriber,can you also please navigate me to the document from where you attached this picture? Thank you.
July 15, 2021 at 12:33 pmEmperor
SubscriberThis document is a pdf that I have in my documents. It is a lesson on contacts. I can't put the document on the platform, but I can send it to you by e-mail if you want
July 15, 2021 at 2:13 pmRameez_ul_Haq
Subscriber,are you talking about Ansys 9.0 Contact Guide?
July 15, 2021 at 2:25 pmViewing 8 reply threads- The topic ‘Default value for Penetration Convergence Tolerance and Normal Stiffness of a contact?’ is closed to new replies.
4833
1587
1386
1242
